I use the MTEK gps on my copter. At first it worked fine, but now i need to press the reset button on APM for it to get a lock. I've read that others have had these problems, but no solution.
Im using the NG code. Is there a solution to this??
I had an issue with my MTEK where it dropped out of the special binary mode back into the default NMEA when my module got cold. I added an XBEE command to send the command out to reset it back to binary mode (similar to pressing reset on the APM) and it worked for a few seconds and then went back to NMEA. My solution was to buy a new MTEK and that fixed it for me on NG.
Heino
