Arduino microprocessor
Not using the custom binary feature
Can I power up my GPS, let it get a lock, and then put it into some kind of low power consumption mode until I need it?
What command would I send to turn it down and then back up?
I also want to change the Hz and baud rate in Arduino's setup method. I found these commands in the MTK Commands document but not the low power or sleep command(s).
Thanks!
Bob
You can turn off WAAS and/or SBAS to save power. I don't know if it is already done by a powersave command.
Of course as soon as I post, I think I've found the answer.
To go into power save mode:
$PMTK320,1*26
To turn off power save mode:
$PMTK320,0*26
I got these from the mtk_packet_user_manual.pdf and not off of DIYDDrones so I'm a bit skeptical. Are these commands correct?
Thanks,
Bob
