  • I am new to this put I believe when you are on the command line that MavProxy is running on you cat issue the command:
    output add 192.168.14.82:14550
    and then you can see your outputs with just issuing the output command.
  • yes it can, its pretty easy you have an out parameter for each UDP client, I do it for feeding GCS in laptop and android phone
