My Heavy Lift U8, Pixhawk - Sweep heads South
3691157515?profile=original
A successful build of my heavy lift quad copter.
Thanks especially to William Cox and Steve Keep - it is now flying a lot smoother.
Specifications:
  • Pixhawk
  • U8 motors
  • 70A ESC
  • 10S 8Ah (2 * 5S)
  • 28" Carbon fibre props
  • Aluminium frame
  • Weight (no payload or batteries) 4.1kg
  • Water resistant
  • Lunch box :-)
Successful flights:
  • 5 minute test flight at 12kg
  • 24 minute down to 3.57 volts per cell
Issues:
  • Loiter stability - everything stable except loiter
  • Needs a larger box
Attached is my parameters. I read a lot about people not sharing parameters. And these need a lot of work, but here they are... shared...
In the next 4 weeks it should be flying down in Antarctica doing some radio tests to wave buoys and photos of sea ice floes.
Sweep 2014-10-22
  • Thank you very much for sharing!!!
    I'll try this parameters and share my experiences and possible modifications.
    What U8 are you using (100, 135, 170)? mine are 135.
    • 100KV - thus the 10S :-) What batteries are you using?
      • 6S.
        Another difference is that I am using "plus" frame type instead of X.
        • Cool. Not familiar with X vs +, what are the advantages / disadvantages / compromises :-)
          • I do not know if X type offer advantages, but it was one of the changes I had planned to improve my setup, and if it's working for you...
            how stable it is in Loiter with that parameteres?
