My Pixhawk Setup
I was able to get 5 flights in today mostly in loiter and it's pretty rock solid. I am curious what it will do with a little wind.
Here are my params for a Trex 550 stretched to a 700 running 1500 RPMs. 3691129941?profile=original
3691129897?profile=original
Trex 3.1.5 001.param
  • Hey Sean, could you share your 3d printer files for the pixhawk mount and GPS mount with me as well. My email address is rkeith3472@gmail.com
    Thanks Robert
  • Hi Sean, I know this is an old post but any chance you could share your 3D printed files for the pixhawk mount and GPS?
    Thanks Kyle
  • Hi Sean,
    Thank you for the param file you had shared last time. It works great with the pixhawk. I had to make very little changes in it to get my 550L dominator flying. I could complete a waypoint mission as well.
    But the problem is with the battery. It hardly gives me 4-5 min of mission time. My headspeed is 1400. I want to go on longer missions. I tried to put up 2 x 6s x 5200mah x 25c batteries with Talon 90. But it reduced my flying time to 3 min. I guess the weight of the battery is too high compared to what it can offer.
    I had earlier read up Rob Lefebvre's comment that 550 is an inefficient machine unless it is stretched to a 600 or 700. I plan to stretch my 550L dominator to a 700 like you to get 30-40min of flying time. I plan to order the following parts:
    Tail boom - 700L size
    Torque tube - 700L size (with extra bearing)
    Rudder control rod - 700 size
    Tail boom supporting braces - 600 size (700 size braces have M4 bolts - not suitable for me)
    Tail blades - 105mm
    Main blades - align 700mm or 720mm
    My questions are:
    1. Do I have to change the rotor head completely for the 700 blades to fit properly? Or is it enough if I just order the main blade holder (would it fit on the stock main rotor head)?
    2. Do I have to elevate the vehicle by changing the landing skid so that the tail blades do not hit the ground?
    3. My motor is BL-730MX (850KV). I am not sure if this stock motor can take the load of the 700 or 720mm blades. Do I need to change the motor too, like you did?
    4. What batteries do you use to get this 35min flight time? Thunderpower 70c ?
    Can you please help me out with these questions? Thank you for your time.
    - Regards
    Rish
    • Rish,  Are you sure about your head speed.  1400 with stock 520 or 550 blades is very low.  You should be able to get close to 10 minutes with a 5 amp pack and stock blades at 1800 ish headspeed.
      David R. Boulanger
      • Hi David Boulanger,
        I had checked up your modification too :) . But I was keen on trying to stretch it to a 700.
        I fly with the 550 size blade. I do not practically have any extra payload other than a crossbar and the mounting for the pixhawk. But I suspect that my batteries are not up to it. With new batteries of the same specs I had mentioned in my previous reply, I used to get about 12-15 min on a 550E (flybarred) with 520 size blades at 1400 rpm. But with this dominator (550L) I am not able to replicate that. My battery weighs 800gm.
        I programmed Talon 90 for 1400 rpm and measured the rotor HS with the optical rpm measuring tool. http://www.helipal.com/magic-mirror-rotor-head-speed-tachometer.html . I don't have any reason to suspect either of them.
        The ambient temperature here is about 40-45 deg centigrade at this time of the year. So, I guess battery performance is effected. Even the motor heats up pretty quick.
        - Regards
        HeliPal.com - HeliPal
        Buy / online at the lowest price. HeliPal is famous for their Fast Shipping, Low Price and Good Service. HeliPal is the best and the biggest rc hel…
  • Hi Sean / Anybody,
    I am an enthusiast trying to mount the pixhawk on a t-rex 550 dominator. I had earlier used the APM 2.6 on a quad and it is awesome. I wanted to try the parameter file mentioned here. But not able to download or view the images. Have they been taken down? Or is it a glitch. If you don't mind, can you please mail them to rishi2009k@gmail.com. Thanks.
    - Rish
    • I haven't flown the Trex-550 in awhile. Attached is my most recent log file for the 550.
      Trex 3.1.5 004.param
      • Got it... Thank you !!
  • Thanks for posting.
    These helis, in my experience,are very resistant to wind.
    I have flown my helis in gusty winds up to 30mph. At those winds the pixhawk handled pretty well. They fly just as well as in calm winds.
    I like the braided wire covers. It helps the setup look really clean.
  • Can I ask where that GPS mast is from?    3d printed?
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
