I am planning a heli drone build and have a couple questions. I will keep adding as I go.First, can I work the programming bugs out on a cheap 450 and then transfer the hardware to a bigger platform, such as a 500? I am sure it would require some tuning, but I want to avoid things like tip overs and crashes due to programming errors.Second, what is the requirement for the board location? I would like to set it up on the battery mount (perpendicular to the X a is of course.)Thanks much!
