need help
good day for all
 iam new on the forum, and i am trying to built my own quadro-copter drone. and i would like to spend about 700.00#$ for parts
i am trying to built it big about 700mm
what i need help for is : what kind of flight controller i can buy with GPS, and all the futures needed for my video cam ...etc
and the brush less motor that can carry about 3.5kgs
and the esc ..
and the best way to connect all that.
    • no no the Max.thrust: 3500g of the brushless motor
      • ok
        So to be able to carry 3.5kg you will need twice as much thrust.
        So do you want to carry 3.5kg of do you need 3.5k thrust?
        • what it is the difference between carry and trust
          someone explain to me if a motor trust is 3.5js x 4 motor = 14kg  = the quadro coptor can carry 14kg , how truth is that? as i have saied i am new on this and i do need help from ppl who has a lot of experience on this
           thank you
          • Ok so lets say you have 4 motors that put out a combined thrust of 3.5kg and your quadcopter wieghs 3.5kg they cancel each other out and you won't be able to lift off.
            For an effective machine, you need motors that put out a combined thrust of twice what the entire machine, with batteies and what ever payload you want to carry wieghts.
            So lets say you want to carry equipment of 3.5kg, you then add the total weight of the machine's hardware and multiply the result by 2.
