Need help completing a drone build
Hi there,
years ago, I had set on to create a drone from scratch - i was following a blog tutorial (https://blog.prusa3d.com/how-to-build-a-3d-printed-micro-drone_29310/)
I had soldered the motors to the main board tower (which consisted of the ESC + Flight controller) - connected the battery, and then i was able to spin the motor, via sending a signal to the main board, while connecting the board to my computer, via USB... I thought it was nearly ready - but then i got distracted, accidentally plugged the ESC board into the Flight controller incorrectly (they are like stackable boards),  and fried one of the boards - wasn't able to get that to work for a while... then I tried to buy the same ESC + Flight controller again, but it got lost in shipping (this was in 2020, when the pandemic started) and then i was not able to purchase the same board again, since it is now discontinued ...
My question for you guys is - am i able to re-use parts that i've got (the motors, the battery, the transmitter/receiver, camera) & drone frame, and rebuild the drone, using similar parts ??
These are the parts i have -
Originally I needed the  - https://drone4racing.com/products/hglrc-xjb-f413-omnibus-f4-flight-controller-13a-blheli_s-2-3s-4-in-1-brushless-esc-for-rc-drone => to complete my build - but most places have it sold out, or when I buy, they send something else (last time i tried to purchase, the seller sent me a cheap ring!)
What i think I need - is a ESC / Flight controller stack, which is compatible with my transmitter/receiver & motors, camera, battery => which would fit in the drone frame that i've got (the toasted flight controller is 20x20mm) ..
I was looking at these options -
But i'm not sure if they will be compatible with my project, would anyone be able to point me in the right direction ?
I'm trying to avoid buying parts that wont be compatible, as this project has already gone over my budget :(
Things which concern me:
1) I am confused by the firmware / software controller system of the ESC/Flight controller (Betaflight ? EMU flight ? INAV ) - my understanding of these softwares - is to calibrate the flight controller, to the motors
2) voltage requirements for the ESC/Flight controller - since the battery pack i've got is a 2S - will that have an issue for the 'newer' flight controllers that are out there ?
I would really love to have this project completed, instead of it gathering dust in my garage :)
Cheers,
Jaz
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
