Need help configuring MinumOSD
I feel bad because I keep asking questions and have nothing to contribute back to the forums because I am just learning so I hope you guys can bear with me a little longer.  I am almost finished setting up my APM!!!.
My problem is with the minumosd.  The only way I can get it to display is power up the system, unplug my fpv camera and then press the reset button on the minum osd which will cause the osd to display on my screen.  I can then plug the camera back in and I get the overlay over my live video feed.  If I do not unplug my camera first the osd will not display at all all I see is the live feed from the camera and if I press the reset button the live feed goes blank for one second and then comes back on.
Am I at risk of losing video mid flight because of this?
Also is there a way to configure the display to make it less cluttered?  if you look at my picture you will see that it is cutting off the GPS coordinates (which I would really like to see completely, just in case).  I would like to have just the artificial horizon, RTH arrow, battery votage, and gps location display if that is possible.
I have searched the forums but can't seem to find any solution to the reset problem or how to configure the display.
Any help is GREATLY appreciated.
Thank you!
  • I think your problem stems from your camera's compatability. Perhaps it's a PAL camera and the monitor is ntsc?
    Do you have another camera you could try? Maybe even a video camera to test with?
    You need to be seeking help here:
    http://www.diydrones.com/forum/topics/adding-extra-functions-to-min...
    You should download the new firmware and Charset from the MimimOSD-Extra project.
