My setup:
DX5e 6-channel radio
AR600 6-channel receiver.
AR600 channel 6 connected to APM channel 8. AR600 channel 5 connected to APM channel 7. APM channel 7 set to mode select. This way I can engage the hardware failsafe to go to manual mode by holding the bind switch, and I can switch between 2 modes with channel 5.
So, I want to know how to set up the failsafe. Ideally I would be able to select between FBW and auto on my ch5 switch, while still having an RTL on signal loss.
If you are using ch8 for mode selection then the hardware mux will put you in manual regardless of what flight mode you assign to position 5. You may think that is annoying but not nearly as annoying as the dev team finds explaining again and again to people why when they assign some mode other than manual to position 5 it goes to manual anyway (by hardware). Consequently it cannot be changed.
Yes, the two parameters (long and short) just determine whether Loiter and Auto modes are disturbed by a failsafe or not. The manual explains that on this page - http://code.google.com/p/ardupilot-mega/wiki/Failsafe
If you find the documentation lacking there is plenty of room on the dev team for anyone wanting to work on it ;)
Failsafe is a confusing subject, because there are several features called "failsafe". It sounds like you already understand the "hardware failsafe".
To set up the loss of signal failsafe for RTL to this:
Excerpt from AR600 manual:
So, how do I set up APM to work with this failsafe? How do I ground test failsafe?
