Yestarday i flew my APM in a skywalker for the first time and had a couple of questions /concerns first i flew in Manual mode and everything was fine when i switched to stabilize it would stay in the air but shake allot i know that means the gains are too high i was using the recommended skywalker config file , that i downloaded but it had the gains way too high for some reason
so should i just use stock gains and go from there ?????????????????????
the other thing was it seemed that the board was resetting in the air or something like that a couple of times i put it in stabalize mode and i would loose connection with my laptop and the gps would restart or something, and i think the board was resseting
some info on my setup i am using just the BEC inside my 50A ESC and not an external one.
is it possible that the BEC in the ESC just wasnt good enough ???????????????
also i flew for well over 20 min. in manual mode and never lost the link then its when i put it in stabalize mode and it was shaking like crazy the board would reset
so what should i do first ??????????????????????
thanks in advance !!!!!!!!!!!1
Martin, Both thanks guys !!
