New APM 2.5+ Issues
Hello all!
I just received my fancy new APM 2.5 from 3DR, and I must say that it is sweet goodness. Although I am having some issues:
*NOTE* CLI Works only on first connect of power, log download only over USB
Opened com port
Init ArduPlane V2.73
Free RAM: 2659
l3No dataflash card insertedCCompass initialisation failed!
Press ENTER 3 times to start interactive setup
3<startup_ground> GROUND STARTu3Demo Servos!=?ArduPlane V2.73]
ArduPlane V2.73]
ArduPlane V2.73]
ArduPlane V2.73] ?
Commands:
logs
setup
test
reboot
help
ArduPlane V2.73]
As you an see the no data flash/Compass issues. It doesn't detect by Ublox GPS either. I have tried to enable them via the CLI to no avail. I have also tried the ArduCopter firmware to see if anything would "Magically" Work. I Can communicate with it just fine. I just can't view any logs, or enable compass/gps. So no real time stuff is displayed in the flight data. Any one have any good pointers? I have already shot an email over at help@3DR. Thanks!
  • Just an update. 3DR help has already assigned me an RMA number, and are going to provide a shipping label! I am so glad that I bought from 3DR and not some clone manufactuer. Hard telling what sort of service I would of got with another company
  • Well...I guess your right. I was stuck at the APM2. Sorry for that. Maybe someone else has a better idea what the problem might be.
  • But it is built in on the APM 2,5 no?
  • Based on the message above.....Remove and reinsert the micro sd card. It's needed to save the logs if i am not mistaken. If the card is not working then it may be bad and you could try a different done (e.g from a smart phone)
