My APM2.5 just quit working while I was doing the final setup on my plane. It will no longer connect via Mavlink or 3DR telemetry to MP. At the time, I was mixing rudder control on my DX7-s to operate the FPV camera PAN servo with the GEAR switch. Everything seemed to work great, then the APM went completely dead. The rudder travel was set at 150% for the long rotation servo.
I had 3DR telemetry, FPV w/ MinimOSD, operating perfectly, Spektrum radio was calibrated and had 3 modes: MAN, STAB, RTL programmed. Aircraft surfaces responded to STAB correctly, then suddenly, nothing.
I disconnected everything including the GPS, and connected via USB to the MP. Connection fails at "Got param GND_ABS_PRESS" (62 of 183). I got access via Terminal and reset the EEPROM: no difference. I have since tried loading other older versions of Arduplane, but there is no accel, mag or GPS response.
Below is the schematic of my flight system. I can not see any reason for the failure due to my design. Please look it over and see if it is all correct. Also, I video recorded the functionality of the system prior to failure so that I could feature it on my website. I can post that video as well. Everything was working perfectly before the sudden failure.
Any help appreciated. I just went from "Ready For Maiden" to "Totally Discouraged".
3690999949?profile=original
  • Here is a revised schematic with the mod you mentioned and the rails corrected. The Pan servo is a Henge MD260 with 600mA draw. I did not exceed the max by much, but that may have been the culprit.
    I am not sure what to try next on the board. There is no apparent damage to it, but I can not get into "Logs" on the Terminal to erase them, and nothing else seems to make a difference. Resetting EEPROM, loading Arducopter or other versions of the firmware result in the Mavlink not being able to complete the connection.3692636892?profile=original
  • Well, I didn't have a second power supply to the Output Rail. My mistake. I guess I was confused by the new supplied APM Power Module (rated 2.25A) and the absence of the JP1 jumper.
    I tested and found continuity across the fuse near JP1, which I hope is not a bad sign.
    Below is my revised Electrical Schematic. I believe I have it right now. May have costed myself an APM in the process tho.
    3692637026?profile=original
  • Sounds like your pan servo drew more than 0.5A and blew the fuse on the APM.
DIY Robocars via Twitter
Sunday
Nov 24
Nov 24
Nov 24
Nov 24
Nov 20
Nov 20
Nov 8
Nov 8
Oct 23
Oct 23
Oct 23
Oct 19
Oct 18
Oct 13
RT @araffin2: 🏎️ After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL. 🏎️ Each part is…
Oct 13
