Hi guys,
I have been working over the past year on a new aircraft/near space craft design. This journey began back in August of 2012 and it has come a long way since then. The goal of the project was originally to simply design a reusable platform for high altitude photography, such as what has/is becoming incredibly popular to do with high altitude weather balloons. Originally we'd considered simply using a glider with an autopilot and drop it from a weather balloon, but our goals continued to multiple and it wasn't long until we'd decided on designing and building this platform completely from the ground up. What we settled on is the craft that we have dubbed the SV-1. Shown below is a front isometric view of our final design for the SV-1 platform.
The SV-1 is a, VTOL semi-autonomous hybrid composite aircraft that utilizes lighter than air gases to either offset the weight of the craft or as a lifting agent to get it up to a high altitude at which point it would be vented off and the vehicle would fly back via autopilot until in range of FPV and traditional remote control systems. It has a number of attributes that we think will make it a rather desirable piece of equipment in the realm of UAVs. Potential applications include, but are not limited to(feel free to suggest any more uses for this that you can think of):
- High Altitude Photography
- High Altitude Research
- High Altitude Reconnaissance
- Long Range High Altitude Reconnaissance
- Long Term High Altitude Research
- Traditional Recreational FPV Platform
- Traditional Recreational UAV Platform
- Traditional Commercial FPV Platform
- Traditional Commercial UAV Platform
- VTOL Recreational FPV Platform
- VTOL Recreational UAV Platform
- VTOL Commercial FPV Platform
- VTOL Commercial UAV Platform
- Unique Situation Deployment
ex. Hard to access area exploration.
- Exotic Air Frame Development Platform
- Multi-Autopilot Experimentation Platform
- Exotic Construction Methods Test Platform
The final design is supposed to be 15ft long, with a wing span of 15ft as well. Our goal is to have it come in around 10 pounds including payload. The current plan is to construct it out of polystyrene and coat it with a polyurea hybrid composite to give it a little more strength as well seal it up/give it a smooth surface. Those composites happen to have rather ideal properties for operating in extreme temperatures, so they should be ideal for our high altitude aspirations as long as we can get the craft to come in light enough while using them. We will be calculating this as well as doing some test samples to make sure we can make our weight goal before we go ahead and start constructing this.
Our ETA is currently a little up in the air as we're not sure what kind of production time we're looking at for this as there is still a lot to be done. Our original goal was to have it done by this summer, but it may be next spring or even later when this gets built, if it gets built. The future for this project is a little uncertain at this point but we have high hopes that it will get built at some point. We are planning on funding via a Kickstarter project when the time comes to build this. We will also be using this, the data we've gathered, and the half scale prototype that we built earlier this year to enter the Google Science Fair.
We did build a half scale proof of concept earlier this year and successfully fly it. I will be posting the video of this flight as soon as we finish editing it. I'll also attach some photos of it along with this post.
This whole aircraft design was part of a larger project that we called, "Project: Dream Chaser". While this platform was the main agenda for the project along the way we have had many little off shoots come up. By the end of the year we have other smaller projects related to this that we hope to accomplish.
- Reusable free flight high altitude balloon.
- Found an organization to promote development of aerospace concepts and designs.
- Set up a set of guide lines distinguishing a new class of aircraft/space craft that we feel is the future in the aerospace industry.
We would love to hear some opinions, suggestions, comments, constructive criticism, or even questions that you have for us on this. Looking forward to hearing what you guys have to say about this stuff.
Thanks.
Note: I've put some CAD images below of the final design for the SV-1, some photos of the prototype, the building of the prototype, and the CAD drawings for the prototype as well. I'll get some flight footage posted as soon as it gets finished.
All rights reserved: www.awkengineering.com
That was a major concern after we flew the prototype. It was lacking a little bit in the yaw department, but we think we'll have fixed that with the actual SV-1. It uses control surfaces for pitch and roll, but yaw is still controlled with throttle differential. If you look at the top view of the SV-1, the ducting actually increases the angle of the air exit for the main ducted fans while also increasing the velocity of it. That coupled with the distance from the CG should give us a very good lever arm action so to speak. Also we've increased the EDF size exponentially. The prototype was 10ft long with EDFs that were maybe an inch or two in diameter. The SV-1 will have two 10" EDF units for forward propulsion/yaw control. Wind will definitely still be a huge concern though. This won't be something you'll take out flying if it's very windy. It just has too much area for the wind to catch. That being said it shouldn't be as bad as say a traditional blimp since we choose an elongated envelope shape vs a typical ellipsoid in an effort to cut down the size of the side cross section.
pretty damn awesome, only worry is the wind, with such small propulsion units this thing will get bumped around
1
2
of 2 Next
