Our next Virtual Race will be on June 4th:
https://www.meetup.com/DIYRobocars/events/285787423?utm_medium=referral&utm_campaign=share-btn_savedevents_share_modal&utm_source=link
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Fred ,
Thanks for your answer. I have the com port set to 57600 8N1N (as well as the Ardu Planner ( which I believe may be irrelevant for a software upload)
At this I am looking for some instructions on how to "manually" talk to the boot loader and get the new firmware uploaded.
Or figure out why I have a communication mismatch...
Can anybody help me please?
Update - no success :(
FTDI cable from Sparkfun arrived yesterday.
Double checked pins and connected to my laptop.
The Modem fired up and the APM planned saw it as a local radio wit the old 1.3 software.
I pressed the upload firmware button. It connected erased the firmware and ended with
"Update Failed SYNC LOST"
Fail: lost Synchronization with Boot loader.
The red LED stays on indicating boot loader mode.
I tried 9600 baud as well as the 57600 with the same results.
Suggestion welcome
Matthias
TTL cable was ordered yesterday from Sparkfun I assume once I have the radios on the same rev my issues will go away.
Thanks you for everybody's help.
I'll keep you posted!
Matthias
+++ that will be helpful l! Thanks! I'll try that when I get home ...
Trige,
OK so I reread the documentation and some other posts. and I conclude that both radios need to be at the same rev level.
I received an unmatched pair.of Radios :( and in order to fix that I need an "FTDI" cable.
(Or I could make my own can make my own Serial Cable).
Will This cable work:
https://store.diydrones.com/Remzibi_OSD_cable_p/ttl-4pinftdi.htm
Or Can You recommend a better cable?
To Clarify assuming you have a matched pair, The upgrade option in the mission planner does not help until ONE HAS A FTDI CABLE that will allow the upgrade of the remote radio as well.?!?
Or can you Upgrade over the air if the radios talk properly?
2nd Challenge
I can issue AT commands to the Radio all day long but I am not getting an answer. ( echo)
Its' been quite a while that I messed with At commands but ATE1 I believe should turn on echo mode.
I am getting absolutely nothing back from the radio.
Thanks for you help...
Matthias
My Terminal Output Looks like this ( see below) the command do not appear to be accepted
I am using Putty
BTW the my win 7 ultimate did not recognize the modem/ radio So I installed the FT232R Drivers
The mission Planner was receiving data after that but It behaves different from using a USB Cable.
I do not seem to be able to send commands to the APM with the radios.
Hmmmm ....If I go to the Setup screen for the 3DR radio and click on "Load Settings" the local radio reports Rev 1.5 the Remote is at 1.3 Is that normal ?
w"È'`èQ
Uxx
KUy*øÃU%z O'C F<(ÝU{>ÀƸR½®U|I(þèU}%ZÛ
¬U~#ê[ÛÛÛÛê&UO3X½Û-<ȯ!?(6»r£»½z;;ÂÎ;(<<ÓÐ5:ºUËU»½tj;;Çë;(2Ê<à ï;Qê\ÛÛÛÛ¡U Tc̽yÂ<Ç6«?;¾H¢ºv¦ºA¦-»UJ@ƸRÜeU
"ú'`è(~UxU~U*³`U% YÈC F<k±U>ÀƸRÈI(ËU%ZÛÌþU#ê\ÛÛÚÛ(
U YD½ÅÚ<È>Ò?"7»MU£»½P;;Ý,;(^Ù<Ò $;¹ôkÂýU7UïU
",'`è)UxÄU*:]U% ^¸@C F<ä/U >ÀÃ×
fU¡I(_EU¢%ZÛ\U£#ê\ÛÛÚÛáSU ¤^Ľì<ÉÈ»
k·;
Hi Matthias,
It shouldn't lose the link easily. What parameters do you have set?
If you use a terminal, try AT&T=RSSI and look at what is happening with the signal and noise levels. You could also do AT&T=TDM if you want to see low level debug information on the TDM synchronisation.
Cheers, Tridge
