no connection possible with XBEE pro 2.5 60 mw
hello,
i have probs with integration of my 2,4 ghz  (xbee pro series 2,5 rpsma)
i use sparfum usb-adapter on ground and sparkfun adapter with solder pads in the plane.
i read the manual....
GND ardu  ->  adapter GND
5 V   ardu  ->  adapter  5V
OUT  ardu  ->  adapter DIN
din led on plane xbee blinking fast.ok i think.but  the xbee on pc side make nothing.only power led is on.no data received by gcs.
i set on both xbees bd rate on 38400 bd and booth modules have the same VID.
have somebody the same module on the plane and can help me to find the issue ??
olli
  • Hi,
    May I know how do we interface the Xbee Explorer Regulated on the Ardupilot Shield with the Xbee Explorer Dongle on my PC? And can we connect the FTDI Cable directly to the Xbee Explorer Regulated?
    Thanks for the help.
  • oh i found the issue...
    on one xbee i must change the firmware..
    for people wich use the same xbee´s and have problems, read this paparazzi info:
    Setup
    For the ZigBee ZNet 2.5 and ZB modules to work one of the modules has to be flashed with the coordinator firmware. All the others in the same PAN can either run as routers or end-devices.
    * Flash one module (ground station) with the coordinator AT firmware
    * Flash aircraft module with router or end-device AT firmware
    To allow modules to join any PAN set the PAN ID to zero (default setting). Then the coordinator will generate a random PAN ID and routers and end-devices will join the first PAN they find.
    If you operate in an environment with multiple zigbee PANs it is recommended to set the PAN ID explicitly:
    * Set PAN ID to some unique (but same) ID on both modules
    * Set a Node Identifier for each module (e.g. ground, aircraft)
