Hi!
I can't get the OSD to show any values. They are all zeroes. Iv'e done a lot of googling but havent found the key yet.
MinimOSD v 1.1 with firmware 2.0. Updated charset. Bought a cable on Ebay to use telemetry at the same time.
APM 2.6 with Arducopter 3.1.
I switch it on, it says "Waiting for mavlink". I connect the telemetry. The previous text will go away and everything seems fine, all the text is there, but it is all zero/null values. The Heartbeat icon is flashing.
I read about the Arducopter not sending values by default, that you have to set the SR3-parameters. But like someone said, that are not there!
Also, going in to MissionPlanner / setup / Optional Hardware / OSD and clicking there, does nothing.
I tried using another MinimOSD that i took off of my Octocopter, that one shows the exakt same. But on the octo, it works with another APM 2.5.
I get the feeling that the APM is not sending out the data that the Minim needs to hear?
Please help, my hair is getting grey over this one...
Yes, all the data shows in MP.
Then there must be data coming on the TX from APM. Your sure the split cable is correctly wired??
