I'm a newbie to the Mission Planner
I have a Fixhawk from RCtimer and I've installed mission planner.
I was able to get through the calibration fine, but when I got to the point of setting up the flight modes they where empty and nothing on the pull downs.
I wanted to use mission planner because my motors are calibrated with the board but they don't spin up fast enough for flight.
I think I found a fix for that in parameter settings under (Thr_Max) and setting the values to 10000 instead of the default value.
I installed APM software and was able to calibrate and determine the flight modes fine, but I couldn't find the parameter settings to increase the throttle.
APM program is similar to MP but the text is rather small and hard to read on a laptop
