No one has the same problem?
No one has the same problem?I still use the same software!I can not understand!ThanksPeter(Hello,now I've started the first flight tests.The RTL system works very well!But if I transfer the waypoints, the Telemtrie shows a speed of 220!I can only with calibrate the sensorswith the jumper, and the display of the pressure sensorreduced to zero.If I then transfer the waypointsthe telenetrie shows again 220I'm using the newest version of Arduopilotconfig ProgramI look forward to a responseThanksPeter )
  • Hi Chris,
    today I was able to finally try my new ublox gps (Ardupilot code 231, configtool 1.4.11).
    At the field I had the same problem: after calibration, made as usually, ardustaton showed airspeed 220m/s, wrong altitude (about 340m at ground) and wrong home distance (not shure about this...)
    If I put the rc in WP or RTL mode, throttle was not working, of coarse why it noted a plenty speed.
    I removed the Ardupilot to watch for some pitot tube bend or whatever else and reinstalled in the plane. After that (and a new calibration procedure) all was working properly, plane flew waypoints and altitude with improved precision, compared to the em406.
    How can this happens?
    Thanks!
    Ric
  • Hello Chris
    now the Sceenshot
    you can see the Speed
    Regards
    Peter
  • Hallo Chris
    Yes, I have the tube in the top nipples
    It does not matter since it is on the ground
    When I set the home point with the jumper
    does the speed sensor work OK! ( I can fly and test RTL )
    only when I transfer the waypoints shown on the Speed Sensor 220
    Then I cant fly a mission
    Jordi says that it can be a software error
    But then so would all have the same problem.
    Danke
    Peter
    Do you have the tube in the top nipple?
