Hi everybody. I have apm2.8 with BeStar BN-880 (U-blox m8n) gps.In u-center everything is ok ; i am getting 7-8 sats. in indoors with hdop1.1.When i connect to apm via usb everything is also ok.But when i connect the battery to power module which powers the apm, escs. and everything else; gps is getting crazy. For one second it captures 5-7 sats than suddenly nothing; no satellites. Gps is at least 15cm away from escs.Any ideas??? Thanks.
you have interference somewhere, does the problem get better if you move the GPS further away? als try shutting off as many things as you can to try to eliminate the suspect one......or it could just be a bad GPS unit, is certainly possible. I have an M8N also and works perfectly with setup almost identical to yours
