Hi. I've updated today the APM Planner and the latest firmware to my Arducopter. I used to be able to make sensor reading via usb (switch away from servo connectors), and now I'm not. I believe to be something different in Arducopter firmware because this happens with version 0.434 also. The reading is fine via XBEE at 57600 however no radio and motors info. USB connects fine, gets data from gps module (as verified in HK station), however no feedback in sensors raw data display nor the main screen instruments. Has anyone had this problem ? Am I doing something wrong (APM ver. 2).
    can you tell me what versions your are running, both planner and ac2? ac2 you can get from the terminal screen.
