Hi All,Is is possible to design a UAV that uses its entire body as a rotor during take-off ?Concept :In this UAV vertical take-off does not require an external rotor or a thrust/weight ratio greater than one. When this UAV reaches a safe altitude, it transitions to horizontal flight.When this UAV reaches a safe altitude, it transitions to horizontal flight.Landing is the same sequence in reverse. The retractable landing gear ends in a simple rubber ball. When the engines are stopped, a dollysupports the aircraft on the ground.I would sincerely appreciate any feedback that I get about this concept .Regards,DeboAttached : Video of this concept
https://www.youtube.com/watch?v=hK47qSTLI70
An almost identical approach.
https://www.youtube.com/watch?v=ZL8AUawUXcAhttps://www.youtube.com/wa... all time favorite easystar
Hey,
something similar has been done:
https://www.youtube.com/watch?v=u23Hqq8QbeE&feature=player_embedded
phil
