http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17924
some one have test this motor?
can i use this motor on our arducopter board? (must change PID?)
how about flight duration? can i get more flight duration?
now i'm using 2830-13 850KV , 3000mA lipo,prop 10x45, total AUW=1.2kg i can fly about 7 min.
need an explanation
thank's
i am using this motors.. and I am getting some flip problems.. after a while the copter suddenly flip and crash.. 12 x 4.5 props 4s batteries.. 30jdrones simmon k firmware...
Here is some data I collected on that motor... I think its a good motor..
Eddie
Well to fix this problem, you have done everything I can think of... I did have a copter one time
with really cheep ESCs that had the same problem... I don't remember how I fixed it...
Maybe... try a 5th ESC, different kind, and bypass the APM and check max rpms...
If max RPMs are about the same as the quad, then get a 6S battery... that will fix it...
Eddie Weeks
www.jetlens.com
