Is it possible to have 2 motors driven by the same signal? Could I create an octo on the current setup but just double up on the motors driving each adjacent pair by one signal? It could fly in a configuration so 2 motors form the front side (side by side) and the same for the other 3 sides.
Or if there is any variance in the motor pair would it fight itself trying to balance?
I think the direction that the motors spin is not related to the signal coming out of the APM. It's related to the ordering of the wires connected from the ESC to the motors. So theoretically you could have the same signal from the APM being fed to two separate ESCs and the motors attached to those ESCs could spin in opposite directions.
I've never seen this done so I expect you'll have some problems but I can't think why.
What if the motors are back to back like they have here:
Could I just T the signal line using 8 ESC's but each set connected to the same motor output signal.
