This is a discussion of getting the PX4Flow sensor working with Copter-3.3.1 (or higher).
Thank's
You have an individual batt too?
I'm sorry but I haven't tested Lidarlite till now. It was just mounted , getting powered up and showing the values. I will be testing the Lidarlite and Px4flow in the coming days( Position control and Alt Hold) . I will surely share the results with you.
Thank's Aaditya, I hope I have an electric issue but not shure, I connected by pwm and powered by esc-bec, perhaps I need an individual bec?.
Aaditya: Is your Lidar lite working well? Mine don't look's stable at low altitude.
Hey guys,
Problem is solved. Apparently the wire running from the i2c port to the i2c splitter had some problem. All this for a wire problem. Anyone having similar problems do check this as well.
I have a little technical question. How can we compute the position X & Y based on the I2C frame of PX4flow. Do we need to calculate like ADNS3080?
I have tried the method from https://github.com/eschnou/arduino-px4flow-i2c/tree/master/PX4Flow/... but the data keeps drifting
