This is a OSD for FrSky Smart Port telemetry based on minimosd-extra.
To get this working you need:
- MinimOSD or MavlinkOSD
- UART to Smart Port Inverter https://github.com/razvanstanga/minimosd-frsky/blob/master/S.PORT_inveter.png
- FTDI 5v connector http://www.robofun.ro/conector-ftdi-5v
Installation:
- mkdir ArduCAM_OSD
- cd ArduCAM_OSD
- git clone git://git.razvi.ro/minimosd-extra-frsky.git .
- copy the the content of libraries in c:\Users\YourUser\Documents\Arduino\libraries\
- open ArduCAM_OSD.ino in Arduino
- select from Tools > Board > Arduino Pro or Pro Mini (5v, 16 MHz) w/ATmega328
- upload
Working:
- battery voltage from current sensor (FCS-40A)
- cell voltage (in temperature slot) from lipo voltage sensor (FLVSS)
- amperage from current sensor, old hub vfas (FAS-40/FAS-100/FAS-100-XT) and new smart port (FCS-40A)
- altitude form bario sensor (FVAS-02H)
- gps (GPS V2)
- low battery warning
- you can use Config. Tool to edit the settings
I used the following sources to write it:
https://code.google.com/p/minimosd-extra
https://github.com/zendes/SPort_OSD
https://code.google.com/p/telemetry-convert/wiki/FrSkySPortProtocol
https://code.google.com/p/opentx/source/browse/trunk/src/telemetry/frsky_sport.cpp
Any help on this is welcomed.
  • This reply was deleted.
    • Taranis firmware recognises the Frsky Hub data. I don't have the hub so I cannot properly test this.
      You can look at the Taranis firmware and adapt this OSD for your needs.
  • I just updated the sources.
    - gps (GPS V2)
    • Just found this googling after finding out the taranis has a serial port.
      I am guessing normally this goes on a minimosd installed on the aircraft, but I wm wondering if a minimosd running this could be fed by the taranis on the ground in line with the ground video signal.
      The taranis seems to allows sport pass through. Has any one tried this?
      Stu
  • This is how it looks on my setup.
