Osd Screen switch
I am having issues with my osd that is connected to my pixhawk. I can't get it to work where I can flip a switch and turn the osd off. I have the channel setup on the gui and on my radio. I am unsure what to set mission planner to. Osd works but no switching works. Any ideas
  • Switching is setup on the first screen of the Config Tools GUI for the MinimOSD, not Mission Planner. You have a choice of two panels. The first one you populate as you like, and leave the other blank. Then use the switch setup in Config Tools to toggle between the two.
    • Everything is setup in the gui for osd and it does not work.
      • Nvm finally got it to work. Thanks for your help. I believe my mistake was I thought there were three panels. On Off and a On second panel. Both Panel one and two were nearly the same and when I flipped the switch it was switching but I didnt see anything change.
