OSD working sporadically in the air
Hi all,
3691059355?profile=original
This is my hack on an APM1. As i understand the telemetry this should be ok. So now i have 4 rows of pins that I can connect to telemetry, OSD, IOboard and who knows what else. This worked great with telemetry and OSD for a while but now there are some problems. Might be related to Arducopter 3.xx or new vibration or something else...
The problem I am having now is that everything works great on the ground but in the air the OSD layer stops working. After a while the OSD layer comes on again only to disappear again. Im guessing the problem has to do with sloppy soldering and maybe bad connectors + vibration.
Or is there something more fundamentally wrong with my setup?
  • I improved the connectors and now it works perfectly.
    LESSON: Dont use crappy connectors...
