Overpowered Carbon 460 mm Quad
Hi guys!
Need your opinion on my latest project. I have built 14 multicopters before this inn many sizes from 100 mm Quad to 1300 mm Octo, but this one was a bit tricky. The intention of this creature is to be a small, stiff and robust, with a lot of power. I haven't done any tuning yet, since the maiden flight have been canceled because of the bad weather in Norway. I tried to fly inside today, but vibrations escalated, so I had to put it on the ground again.
I was hoping one of you smart guys could give your opinion on the setup (pro's and cons). I suspect it may be to heavy to be 460mm...looking forward to do some tuning. Will try the autotune, but not inside;)
Not worried about the vibrations, since the landing gear is soft, with 1,3 kg battery. Vibrations will probably disappear when I fix the landing gear mount and tune the PID's a bit....or?
Specifications:
Motors: Multistar 4010-580, kv 22 pole, 550 watt (I love this motors..they run extremly smooth with a lot of power)
ESC: Afro 30 A with SimonK firmware (I know esc should have been 40 A)
Battery: 2x 4S 5000 mAh
Props: 12x4.5 (larger will conflict with the next prop)
Weight: 2600 g with 2x5000 4S 45-90c
Controller: APM 2.6 with external GPS/compass combo
Firmware: 3.1.2
TX: JR DSX9
Cables and plugs: 12 AWG with HXT and XT60
Frame: Custom carbon with 23mm carbon tubes.
Motor mount: Custom, but going to redesign.
3691097746?profile=original
3691097899?profile=original
3691097971?profile=original
