Hello...
I have been searching for 3 weeks with no succes, so here goes:
1. How do I display parameters (AmpDrawn, disttohome, etc) in the PFD window of Mission Planner??
2. Where did Grid planinng go from Mission Planner? In the previous verison, in FLight planner we had the option to choose the grid, and it would generated the path and distances to follow for photogrammetry.
Thanks.
  • Right click on the PFD, called a HUD in Mission Planner, and select User Items.
    For the Survey, right click the Flight Planner map, select Auto Waypoint then Survey Grid.
    First you need to define a polygon. It's all in the wiki.
