Hello,
I'm a newbie to the UAV's and i'm stuck with how to use a sensor with PixHawk.
I'm trying to use a flux sensor that is going to work associated with PixHawk and Here GPS module.
I want a water flux to be measured by the sensor and sent to PixHawk to comand a pump that wil increase or decrease the pumping power acording to the ground speed given by the Here GNSS module.
The thing is, as far as I know PixHawk is not directly compatible with the sensor (link below).
I heard that I could use a Arduino do decode the sensors measurement and send the data to PixHawk, but will that came only with the value on the display or can I set PixHawk to use this value as a parameter to comand a pump.
Thanks a lot!
Sensor: http://www.dx.com/pt/p/hs09-pvc-water-flow-hall-sensor-flowmeter-counter-white-228283#.WS2lQGjyuUk
I couldn't test it yet because I haven't received PixHawk yet and have never used it before.
