Dear All
I am using pixhawk with mission planer . So please advice to calibrate compass. I am using Ublox M8N GPS module
Once I stated compass calibration the result is as per the following video
https://www.youtube.com/watch?v=zJDZyw18ikw&feature=youtu.be
Please advice
Thanks in advance
Dear All my compass detection issue solved after firmware upload using QGroundControl and then re firmware upload using Mission planner then problem was solved
Now I can calibrate compass using mission planner
But at the calibrating there is a massage " new offset for compass 31 are 59-101-48 this have been saved for you'...... so at this time there are pending white box are remaining so please advice how can I complete all the white box cutting by red box without the message
Thanks in advance
Dear Michaele
Thanks for the reply and advice
I agreed with you and I did it but there is no ant single movement of progress window of mission planner and I removed GPS module from the pixhawk and trailed to calibrate internal compass of pixhawk but i did not see and calibration result
Please advice
The compass you are calibrating is the one that's in the GPS module that is not mounted on a frame. That will not work.
Both units most be mounted in a frame so that the compass can take into count the environment. Also the Gyros sense the movement and help calibrate the compass so both units must move together.
