Pixhawk config issues
I am working on configuring my Pixhawk.  I tried different firmwares and the different apps.  Not going so well today I think.  I am not seeing the LED colours displaying in the documentation http://3drobotics.com/wp-content/uploads/2014/03/pixhawk-manual-rev7.pdf
Using Mission Planner
Install firmware 3.1.4
After install I get too tee too, too tee too, too tee too and then beep beep and I click OK
Safety switch flashes very fast, but no colour on the main LED
I plug in the battery and keep it on USB power
Hold down the safety switch, but nothing happens
Unplug everything for 10 seconds
Plug in USB only
Still no main LED colour
Load custom firmware of 07/05/2014
After install I get too tee too, too tee too, too tee too and then beep beep beep and I click OK
Main LED flashes Green, Blue, Red very fast.  That isn't in the documentation
Safety switch flashes 4 times fast
Plug in battery and keep USB in
Hold safety switch in and it is lit, but main LED is still giving us a rainbow
I see it is not happy about the compass and it isn't detecting the GPS that I plugged in.  On the Compass screen the app keeps on going back to the Manual radio button even after I did a Live Calibration.
I don't know what is supposed to happen on Flight Modes.  The documentation says the drop down will go green depending on which switch is selected on the transmitter.  Mine just always has Flight Mode 6 as green
https://www.flickr.com/photos/92380311@N04/13950315147/
https://www.flickr.com/photos/92380311@N04/13950318519/
Using QGroundControl
Go to config
Scan
Install stable version
Main LED does the Blue breathing thing.  Not sure what that is
Safety switch is lit
QGroundControl can't connect to the Pixhawk again
Unplug battery and USB
Plug back in
It does beep beep beep for a couple times and then again blue breathing and now safety switch has intermittent blinking
Holding the safety switch in it now flashes twice fast
Still can't connect to the Pixhawk
I have to then install 3.1.4 from Mission Planner to fix it
Install 3.1.4 in Mission planner
No colour on the main LED again
Back to QGroundControl
Go to config and scan
Install beta
Beep many times
Blue breathing and safety switch flashes once at a time
Blue on permanently
Hold safety switch in and then it flashes twice fast
Unplug and restart QGC
Connect.  Can't connect
This is the log from QGC
[I] LINK COUNT 0
[I] WARNING: Settings loading for trail type (ByTimeElapsed) not implemented
[I] Loading widget: "PRIMARY_FLIGHT_DISPLAY_DOCKWIDGET"
[I] Loading widget: "UAS_INFO_INFOVIEW_DOCKWIDGET"
[I] UDP Created "UDP Link (port:14550)"
[I] ADD LINK CALLED FROM SOMEWHERE
[I] MAVLINK OK
[I] Attempting connection to something unknown with description: "Communications
Port"
[I] Attempting connection to something unknown with description: "X"
[I] create SerialLink "" 57600 false false 8 1
[I] m_portName "COM3"
[I] ADD LINK
[I] MAVLINK OK
[I] SET DATA BITS
[I] current portName "COM3"
[I] setPortName to "COM3"
[I] Attempting connection to a PX4 unit with description: "PX4 FMU"
[I] SerialLink: hardwareConnect to "COM3"
[I] CONNECTING LINK: z:\TeamCitySource\buildsource\qgroundcontrol.origin\instal
ler\src\comm\SerialLink.cc 486 type: "px4" with settings "COM3" 115200 8 0 1
[I] loadParamMetaInfoCSV for autopilot: "PX4" from file: "C:/Program Files (x
86)/qgroundcontrol/files/px4/parameter_tooltips/tooltips.txt"
[I] PARAM META: "BAT_V_FULL"
[I] PARAM META: "BAT_N_CELLS"
[I] PARAM META: "BAT_V_SCALING"
[I] PARAM META: "MC_ATTRATE_P"
[I] PARAM META: "MC_ATTRATE_D"
[I] PARAM META: "MC_ATT_P"
[I] PARAM META: "MC_ATT_D"
[I] PARAM META: "FW_ROLLRATE_P"
[I] PARAM META: "FW_HEADING_P"
[I] silenceTimeout 350
[I] Add new UAS: 1
[I] z:\TeamCitySource\buildsource\qgroundcontrol.origin\installer\src\uas\UASWay
pointManager.cc 990 "Requesting waypoint list..."
[I] ParameterInterface::addUAS : 1
[I] z:\TeamCitySource\buildsource\qgroundcontrol.origin\installer\src\uas\UAS.cc
: 2155 "Thu 8. May 22:32:57 2014" LOADING PARAM LIST
[I] Created "QGCParamWidget 0x331f050 (parent 0x34bcf90)" for UAS id: 1 coun
t: 0
[I] z:\TeamCitySource\buildsource\qgroundcontrol.origin\installer\src\uas\UASPar
ameterCommsMgr.cc 88 Ignoring requestParameterList because we're receiving param
s list
[I] Created "QGCParamWidget 0x331f5c8 (parent 0x5ecba28)" for UAS id: 1 coun
t: 0
[I] Loading custom tool: "PX4 Calibration Tool" "PX4 Calibration Tool"
s list
s list
[I] No parameters defined for system type: "FIXED_WING"
[I] CALIBRATION!! System Type Name: "FIXED_WING"
[I] UPDATE WP LIST IN 2D MAP CALLED FOR UAS 1
[I] DELETING NOW OLD WPS
[I] silenceTimerExpired elapsed: 536
[I] compId 0 readsWaiting: 1
[E] Invalid vehicle dir, no vehicle specific configuration will be loaded.
[I] "C:/Program Files (x86)/qgroundcontrol/files/px4"
[I] "C:/Program Files (x86)/qgroundcontrol/files/px4/general/widgets"
[I] "C:/Program Files (x86)/qgroundcontrol/files/px4/fixed_wing/widgets"
s list
[I] Mark all parameters as missing: 301
[I] linkErrorCount too high: disconnecting!
[I] disconnect
[I] "COM3"
[E] QThread::wait: Thread tried to wait on itself
[I] Closing Port # 317 "COM3"
  • I have the similuar problems like yours.My pixhawk can connect to both MP and QGC after i install apm's firmware(v3.3).but with the px4's firmware i can't connect to MP or QGC .Have you fixed your problem and how?
    You may have a corrupt bootloader. Try powering on with the safety switch held down and keep it held down until the beeping stops. That will reload the bootloader.
    If that doesn't work, you may have faulty hardware.
  • I'm facing similar problem . I tried with apm planner , mission planner and qgroundcontrol.
    mission planner 3.1.5
    success loading the firmware but facing error on mavlink connection cannot bind the connection.
    qgroundcontrol 2.0.3
    3701774582?profile=original
    using the qgroundcontrol I got success uploading the firmware and success linking with mavlink but I couldnt calibrate my Y6 multicopter.
    3701774690?profile=original
    Is there a way to calibrate multicopter without using the mission planner ?
