last weekend I installed arducopter 3.1.5 on my Pixhawk. Its a quad running sunnysky 3108 720's afro20aESC's. After I did the FW change, I noticed MOT_TCRV_MAXPCT was like 89, was highlighted in yellow. I set it down to 80, which made the yellow warning goaway. anyway I did a test flight, and twice (2 different test flights) the quad fell from the sky as if a motor stopped. after reviewing the logs, I see a mechanical failure. my question is the mot_tcrv issue related, also, am i missing something in the logs?
Im not very experienced in analyzing logs, and any help is greatly appreciated! also attached is the full log, with the crash at the end.
You could do an Erase in CLI which will put all the defaults back so you can look at them, Save your current config first and re-load it after.
