Our next Virtual Race will be on June 4th:
https://www.meetup.com/DIYRobocars/events/285787423?utm_medium=referral&utm_campaign=share-btn_savedevents_share_modal&utm_source=link
So, think this will be my final update on this topic. Thanks everyone who chipped in with advice or ideas. This morning I attempted to get the ESC's calibrated and the pixhawk continued to restart over and over, making all sorts of dying robot noises and I gave up.
I waited a bit and through some sort of black magic as I have not idea what I changed, I got it to consistently start and arm...I have no idea what changed. I still could not calibrate the ESCs normally so I tried something one of you suggested and powered just the pixhawk with a battery and got it into ESC calibration mode and armed it with the button, then I hooked up a separate battery to the ESC and immediately I heard the two beeps indicating the top range had been found, I moved it down and heard one long beep indicating the bottom range was found. Then as soon as I moved the throttle up at all they started spinning! I didn't have time for a hover test but it seems to be working.
I don't trust this unit though because I really never figured out what was wrong with it and that doesn't give me confidence in it. 3DRobotics was very helpful and even though I'm a little out of warranty they agreed to exchange it for me which his awesome of them!
Again thanks everyone!
I had an issue where I could only connect to my Pixhawk to flash it.
After about a week and a half of pulling out my already thinning hair trying everything under the sun and hours of research. I finally decided to reformat the SD card..... IT WORKED instantly!!!
I dont think mine was formatted from the start, as the computer had trouble recognising it and promted me to format it.
Also one thing to note;
I have 2 quads, one with an APM 2.5 and one with a Pixhawk.
Both using a Qbrain 25A 4in1 ESC's. I can confirm all at once calibration works fine on them.
Well, so far that seems to have worked! I didn't have enough time to fully test it out, but it appears to be working now! I had a lot of problems with Kingston micro SD cards I my gopro so maybe they are just poorly made. I'll try and get it ready for an actual test tonight or tomorrow morning.
That's what I had to do. Reformating worked for only for a short while. I swaped SD Cards, and mine has been working since.
Happy flying.
http://youtu.be/45XR-rtI-NA
A video of the startup issues... This happens whether I power it with the power module, USB, or the servo rail as shown in the video.
Doesn't sound good does it? Sometimes it doesn't get past the yellow blinking light.
I reformatted the memory card, reinstalled mission planner and arducopter firmware, and updated the IO and was able to do the entire wizard with no issue.
Voltage coming from ESC BEC is 5.5, power module is 5.6 and when I used USB to do the setup the voice kept saying check board voltage but it let me run through it all.
At this point I'm going to see if I can get the pixhawk replaced by 3DR and try again at that point. Don't understand how this would randomly just happen. Thanks everyone for your help!
can you take a pic of your setup?
Hi
I used to run the same ESC on my pixhawk. The fix is very simple. Make sure all your ESC motor connections are connected to your PixHawks motor out ports. Remove all your props before doing this.
Step 1: Power off your copter.
Step 2: Turn on your radio transmitter and then put it to full power.
Step 3: Turn on your Quadcopter and then press the arm switch till it shows solid red. Then remove power to the quadcopter.
Step 4: Turn on your Quadcopter again. You will hear a long beep sound. Once you hear it and it stops press the arm button again. Your ESC will make two beep sounds. When you hear this immediately return the throttle on your Radio transmitter to idle setting. Wait for 5 seconds and remove power from your Quadcopter.
Step 5: Power your pixhawk and arm the copter. Now enjoy the mighty Stability of PixHawk.
Just remember to act fast with the arming button and it will work.
Re-format your SDCard...Doesn't hurt to try.
