PixHawk issue
Hi everyone, I hope this is the right place to ask this question
In my pixhawk an issue happened suddenly , I can't connect it to my PC
( the middle flash stay steady which indicate some I/O problems as I understand )
I checked the voltage regulator and I noticed that the output is 4.7 volt
also I checked the I2C (Vcc and GND) and it gives 4.7 volt also
I think the voltage regulator has broken, does that relate to the usb connection ? or I must check something else ??
I fear that something else has an issue and it destroyed the regulator ??
Any ideas ??
Thank you very much
  • After re checking the regulator voltage it seems that I read the output wrong , so regulator is fine , but I still can't connect my pix to the computer.
