I just built an F450 drone with a Pixhawk. The gps, though plugged in to both ports does not light up. Additionally, Mission Planner says that it can't find any sats. It is unable to triangulate my location. Any suggestions? Thank you!
I can only suggest to double check your pin out. Rx/Tx crossover etc. color scheme for wires ??? .. i bought one off of amazon and it seems to be ok, although I haven't flown it since plugging it up. Good luck.
Hi, I'm having the same problem. I've tried two different GPS modules neither of which light up. I've also tried to power them directly from 5v without success which suggests that it is the GPS module which is at fault as the Pixhawk is supplying 5v. Maybe third time lucky?
