Pixhawk: no output to servos
I purchased the Pixhawk about 2 weeks ago with the matched GPS and telemetry radios.
I have set up the Pixhawk with Mission Planner as outlined in the QuickStart Guide, with the following exceptions:
  • I had to use the "Reset" button instead of unplugging and plugging in the USB during the firmware update process.  Otherwise I got the dreaded "no response from board" message.
  • I mistakenly hooked up the GPS with the 5-pin cable.  The board will not boot correctly this way.
Once I fixed these problems, Pixhawk booted fine and I was able to perform all of the mandatory calibration steps.  However, now I see no effect anywhere when I move the sticks and switches on the transmitter.  The R/C calibration looked absolutely normal (I've done this many times before), but nothing happens when I move switches to change flight modes or move the sticks, which normally causes servo movement in manual mode.  I can't switch to other modes to test them.
I have tried ARMing the system and disARMing it, no effect.
My servos are connected on channels 1-4 in the "Main outputs" section (see attached).
Anyone else seen this?  I'm sure it's something simple, but I'm a bit mystified at this point.
Gary
3691122218?profile=original
  • I also discovered that the flight mode channel is set to ch 8 by default.  Not sure why since 8-9 ch radios are less common.  Went into Config -> All Params and set the "Flight Modes" r/c channel to 7 since I have a 7 ch radio.  After that I was able to successfully change flight modes from the transmitter.
    After this I made my first autonomous flight on Pixhawk!  It didn't follow the flight plan very well, may need tuning or further debugging.
    Gary
  • I managed to get this working.  I read the section of the wiki about arming the throttle.  In the beginning I just had four normal servos connected to channels 1-4 on Pixhawk.  I removed those and connected channels 1-2 to servos and ch 3 to the throttle on a real ESC.  I then clicked on the "Arm/Disarm" button on the "Actions" tab on the "Flight Data" tab.  After arming using the main safety switch, everything started working.  I suspect the entire system was disarmed.  However, when pressing the safety switch, the upper left display showed "ARMED" which is why I didn't suspect that this was the problem.
    Gary
  • Admin
    @Gary,
    What type of aircraft are you using your Pixhawk on? Is it a plane or a multicopter?
    What version of the Ardupilot firmware are you using?
    TCIII Admin
    • Hi Thomas,
      Thanks for the response.  I installed the latest FW from Mission Planner on Saturday.  I just installed v3.0.3, didn't make any difference.  I'm using a 3-channel powered glider, the Dynaflite Piece'o'Cake.  Pic attached.
      Seems like I must be missing a step somewhere.  I'm going to review the LED status.
      Gary
      3702493020?profile=original
      • Admin
        Hi Gary,
        Nice plane. I fly Multiplex EZ*s.
        Have you looked at the ArduPlane Wiki: Link
        TCIII Admin
