Pixhawk with Taranis novice question
Dear all,
Probably being a little stupid but I can connect to the PIxhawk using mission planner and my TX controls calibrate without a problem so I assume the sbus connection from my RX to the Pixhawk is working fine (power going the other way is clearly fine).
However I cannot get any output from the main Pixhawk servo outputs. The pixhawk has a nice large green light and mission planner is showing a GPS fix which looks fine. I believe everything is armed and good to go but no servo movement!  When I plug the servo into my receiver everything works as expected.
What have I missed?
  • Remember that to be able to arm the pixhawk, you must first keep pressed the safety button until you hear a beep and the led pattern of the button changes... only after this operation the pixhawk will allow pwm signals from the servo outputs...
    Moreover make sure you went through all the calibrations (ESC, Radio, accellerometer, compass).
    Hope this helps you... i have the same hardware and everything is fine...
