Possible compass issue?
I am running the 3DR Hexa with APM2 and Arducopter 2.6.
I just started flying it this last weekend and noticed that sometimes all of the sudden the controls go reversed. I am flying in stability mode and simple is checked.
Sometimes landing and disarming and reamring makes it all better for a little bit. Other times I have to turn it off and then back on.
One thought I had was that i am flying in a small area (about a 25 ft circle). Is it possible that simple mode gets confused on where it launched since it is in such a small space and thinks it's now on the other side of where it launched?
I will try and get some data logs. I remember a couple weeks back someone had found an issue with the compass going 180 degrees out but I can not find that thread anymore.
Thanks,
Jeremy
  • Thanks Jason,
    I have attached a log file. It seems that anytime I yaw it throws off the compass. I was watching in the MP and could see the compass still turning when I was sitting still on the ground.
    When I boot it up or if it just sits there for a while it seems to read fine just after a yaw movement by me does it seem to go funny.
    I can't get into CLI as I have another strange thing happening with communications. USB goes nuts. I can only talk to the APM2 reliably with the 3DR radios. When I go to the terminal I get instantly get a scrolling bunch of giberish that won't stop. Not sure if that is related to the issue or not.
    Thanks for looking at this.
    2012-07-03 13-04-31.tlog
    You may be in Super Simple mode, which is a enhanced mode that requires a working GPS.
    You may also have a bad compass. Can you check the compass is working correctly? The CLI has a compass test. And you can also disable the compass and fly Simple mode for a bit and see if it has a problem.
    Your flash logs would help as well.
    Jason
