Premature Flight Battery Voltage Regulation
I have about 7 flights on my Bixler 2 and every time I've flown I haven't been able to discharge the batteries more than 1Ah out of 2.2Ah, before the low voltage cutoff begins to regulate my throttle.  Also the resting voltage of the battery packs after each flight is around 11.7v compared to around 9.6-10 for a fully discharged 3S Lipo battery .
 I believe the ESC is programmed properly for 3 cell's its an E-Flight 30A (EFLA1030) but through all of the beeping it gets kinda fuzzy.
Could the APM have anything todo with the improper discharging?
I've been using Turnigy 2200mAh 3S 25C with only 2 cycles on them since I've purchased them. I know they can output more capacity, from my previous experience with Turnigy 2200mAh 3S 20C which I had but about 20 cycles on before seeing any degradation in capacity and those were discharged at 38 Amps in my Stryker.
Any thoughts on what the problem could be?
Flight times:      8-10 Min
Static current : 12-13(A) without APM installed
Thanks for the help
  • Looks like it's my speed control causing the problem, I'll be using a spare to test if it is the speed control or not. Post to follow!
  • Does the mAh capacity imputed into mission planner have any control over the motor when using the power monitor for voltage and current?
DIY Robocars via Twitter
Friday
RT @_JonMyer: 🏎 We need your help in naming my #AWS DeepRacer Underground Track 🏎 @davidfsmith's track is going to be referred to as 𝗔𝗪𝗦 𝗗…
Thursday
RT @gclue_akira: 仕事もおわったし、電脳化にとらい #マリオカートハック https://t.co/4IU90hCLgm
Thursday
This is the hashtag to follow all the people in Japan who are hacking the new Nintendo Mario Kart with the real AR… https://twitter.com/i/web/status/1319281354664677376
Thursday
RT @gclue_akira: @chr1sa @diyrobocars jupyter mario https://t.co/P0oHdjlCRq
Thursday
RT @_JonMyer: 🚨Our 1st AWS DeepRacer Community Race is Underway on http://twitch.tv/aws 🚨 Join us to find out which member of your commu…
Oct 20
Oct 19
RT @BackyardRobotcs: After an admittedly long wait, the new Tinymovr R3.3 motor controller is now available https://tinymovr.com 🥳
Oct 19
RT @_JonMyer: 🏎 1 hr left before the #AWS #DeepRacer Community 🏎 Top 5 Race tomorrow LIVE on Twitch 1st Place = $50 Amazon GC or AWS Credit…
Oct 19
Oct 16
Oct 15
Oct 14
RT @davidfsmith: Race virtually with The AWS DeepRacer Community Race and then join us on the track to see how your times compare on the ph…
Oct 14
Oct 14
Hiroki Tanaka liked Hiroki Tanaka's profile
Oct 13
RT @breadcentric: It's now!
Oct 13
