Problem compiling Ardustation2
I get this...
Ardustation2.cpp: In function 'void send_message(mavlink_message_t*)':
MAVLink:98: error: 'struct __mavlink_message' has no member named 'payload'
MAVLink:100: error: 'struct __mavlink_message' has no member named 'ck_a'
MAVLink:101: error: 'struct __mavlink_message' has no member named 'ck_b'
Here is the function:
void send_message(mavlink_message_t* msg)
  Serial.write(MAVLINK_STX);
  Serial.write(msg->len);
  Serial.write(msg->seq);
  Serial.write(msg->sysid);
  Serial.write(msg->compid);
  Serial.write(msg->msgid);
  for(uint16_t i = 0; i < msg->len; i++)
    Serial.write(msg->payload[i]);
  Serial.write(msg->ck_a);
  Serial.write(msg->ck_b);
Any ideas?
  • Hi all,
    in case someone would also like to use this code (and ends up having the same problem): it seems that if one replaces the send_message part with something like this
    mavlink_msg_request_data_stream_send(chan, 1, 0, MAV_DATA_STREAM_RAW_SENSORS,
    MAV_DATA_STREAM_RAW_SENSORS_RATE, MAV_DATA_STREAM_RAW_SENSORS_ACTIVE);
    and makes sure the target system id is correct and uses the same way to initialize chan to be a mavlink channel (see e.g. ArduPlane GCS_Mavlink) then it works. Tried yesterday on my workbench with a direct serial connection but of course it should also work with the Xbee in between.
    Cheers,
    Andre
  • The Mavlink library has changed slightly in the latest libraries breaking Ardustation 2.  Compile with the Arducopter 2.0.38 or earlier libraries and these errors will be fixed and Ardustation 2 should still work ok with Mavlink in the later APM or ACM software (such as Arducopter 2.0.46). I'm working on fixing these errors with the latest libraries.
