Problem programing APM
Hello!
I'm having some problems programming my new APM board.
After soldering the headers I tried to load the "dance demo" to the board. The upload works ok but the program doesn't work.
I tried this small program to verify that the board is working:
void setup(){  Serial.begin(57600);}
void loop(){      Serial.print("test");      delay(100);}
The upload works ok again but It doesn't print any output on the serial monitor.
I checked this program test on my arduino board and it works perfect.
The three leds on the board are on (red, yellow and blue) all the time.
What can I do to test the board?
Thank you!
  • Hello again!
    After some more test, the APM is still not working.
    Uploading the code using the APM IMU usb I have the same behaviour. The tx/rx leds of the IMU flash quickly during the upload but after this I have no response from the board and again no output on the serial monitor.
    All the LEDs of the APM board are on all the time (without blinking) even when I push the reset button or the upload code is finished. I don't know if this is the normal behavior of the board but sounds as a problem.
    I don't know what can I do more to test the APM. Maybe this board has a manufacturing error?
    Thank you!
