Problem with 900 Xbee Module
Hi, I recently purchased a Ardu Pilot Mega Kit along with two 900 xbee modules from the store.
Finished soldering up the kit and everything appears to be working fine.  However, I encountered some problems when trying to use the 900 xbee modules.
Actually, its just one of the modules - I can't seem to connect to it.  I've tried every available baud rate on the X-CTU program as well and double checked the serial port number, all to no avail.  I keep getting an "unable to communicate with modem" error message.
The other module connects at the 5700 baud rate without any problem.
I am using the recommended Sparkfun xbee usb board  for the above configuration.  On the IMU side, I have the recommended DIY Drones board but have not used it with the 900 modules because of the above problem.
Is there a problem with the module or am I doing something wrong?
Thanks,
  • Hi,
    I'm getting the same error with the diydrones xbee 900 telemetry kit. The X-CTU program reports "unable to communicate with modem" when trying to communicate via the xbee USB dongle.
    Any advice on how to fix this?
    Thanks,
    Phil
