Problem with IMU
Hello,I would like to help me because I have a problem with IMU.The problem is that when I test the IMU with arduino and IMU is stable (no motion) the numbers (output data) keep changing. for example:r:1 p:0 y:2r:-1 p:1 y:3r:2 p:0 y:4r:1 p:0 y:5....r:13 p:-6 y:60I followed the instructions in the link below:http://code.google.com/p/ardupilot-mega/wiki/IMUand I check my solder joints!Also, my hardware:An ArduPilot Mega BoardAn ArduPilot Mega IMU shieldA MediaTek GPSand others..Thank you very much!
  • Hello Martint,
    Where are you connecting the battery to the APM?
    - I am connecting the battery on RC receiver.. But I tested the IMU using usb cable without battery.
    Is the APM the one with numbers 0-7 or 1-8?
    - 1-8
    If you have checked and double checked the solder joints this might be a fault on the board. I have not seen many failed boards here in the past, could count them on one hand with fingers to spare!
    The number one issue is the soldering of joints, as a precaution have you gone back over all the solder joints and made sure they are all good?
    I checked all the solder joints one by one ... and everything is okay!
  • Hello again,
    Thank you for your reply.
    Is this the first time you have tried the IMU?
    -Yes
    What version of the hardware and software are you using?
    -Hardware: v1.6 (I bought all the materials a month ago)
    -Software: ARDUINO 0022 - 2010.12.24, HappyKillmore's GCS v1.2.38
    What happens if you remove the GPS?
    -Nothing..
    Have you tried to reset the board and test again?
    -Yes
    Have you removed all other items from the board and tested?
    -Yes, I tried only with main board and IMU shield, but nothing happened.
    How are you powering the board?
    - Battery: 4.8V / 1600mAh
