Hi All,
I'm hoping someone has seen this problem... With all the ESCs plugged into the APM, this one ESC starts up at zero throttle. All the others start running when throttle is applied as one would expect.  I've switched the  ESC to a different port and  the problem stays with the ESC (i.e. moves to the different port). This only happens when connecting to the APM. If I connect the  ESC directly to the receiver, the motor doesn't start spinning until I give it some throttle (i.e. it works correctly when connected to the receiver). So I'm thinking the ESC is bad but I'm hoping has seen this problem and can give a little advice.
  • You should re-program the ESC end points straight from the rx ch 3 all together using "Y" servo extensions, or doing them all seperatly is OK too just more of a pain.
