problem with the ardupilt + imu v2 +EM406
hiii
my problem is the blue led on the imu v2 not locked because the baud rates in the ardupilot and the arduImu  not the same ...
can some one tell me where i can find the baud rate in the ardupilot code and in the imu code to change it ..
or if some one can give  the code for the imu v2 and the ardupilot , to work together...
thanks to the all..
    If you loaded the correct code, the baud rates should be the same. Are you following the instructions in the manual? In the ArduPilot configuration you should be selecting IMU as the GPS, not EM406.
    Please re-read the manual and follow it exactly.
