Problem with Write Pids
When I try to adjust PID values using Configuration I get:
'Set RLL2SRV_P Failed' error message when I try to adjust the Servo Roll P value.
'Set RLL2SRV_I Failed'  error message when I try to adjust the Servo Roll I value.
'Set RLL2SRV_D Failed'  error message when I try to adjust the Servo Roll D value.
'Set RLL2SRV_IMAX Failed'  error message when I try to adjust the Servo Roll INT_MAX value.
All others are writing OK.
I am using APM 2.2.0 HIL
Planner 1.0.24 Build 1.0.4201.29409
I flew my Telemaster Friday and inflight adjustments with 'Write Pids' worked great!
Just when I think the Planner can't get any better - you add something to improve it more.
Keep up the good work.
