hi
i am trying to set up mavproxy with a raspberry pi + apm 2.6 using the instructions here:
http://dev.ardupilot.com/wiki/raspberry-pi-via-mavlink/#Testing_the_connection
im up to the "testing the connection" step,
the apm doesnt seem to respond to anything i type
this is what i get in terminal (ssh to the pi from mac)
pi@raspberrypi ~ $ mavproxy.py --master=/dev/ttyAMA0 --baudrate 57600 --aircraft MyCopter
Connect /dev/ttyAMA0 source_system=255
no script MyCopter/mavinit.scr
Log Directory: MyCopter/logs/2015-09-09/flight5
Telemetry log: MyCopter/logs/2015-09-09/flight5/flight.tlog
MAV> Waiting for heartbeat from /dev/ttyAMA0
none of the commands suggested on the above url have any response, idk whats wrong,
can someone please tell me what is happening?
Thanks for your reply Rob.. I even face some problem in starting the isc-dschp server.. stating the error failed, more over i found that etc/inittab configuration file seems to be empty without any script. If possible pls help me with this issues too..
Regards
Nijandan.
Hi Rob
Did you got the solution for this prob?
Coz me too facing the same problem .
yes i did find a solution,
i havent done anything with it in the last month, will need to get my pi back on my network so i can ssh it,
then i will post the solution here.
it will be in about 24 hours from now
13 days later...
I'm having the same issue. Would you post your solution? Thanks!!
Hi Guys,
I am trying to set up mavproxy with a raspberry pi 2+ pixhawk using the instructions here:
http://dev.ardupilot.com/wiki/raspberry-pi-via-mavlink/#Testing_the...
I'm up to the "testing the connection" step,
the pixhawk does not seem to respond to anything I type
this is what I get in terminal (ssh to the pi)
Thanks.
Problem still continue...
Any suggestion on this issue?
Thanks in advance.
