problems with apm 2.6 + raspberry pi mavproxy
hi
i am trying to set up mavproxy with a raspberry pi + apm 2.6 using the instructions here:
http://dev.ardupilot.com/wiki/raspberry-pi-via-mavlink/#Testing_the_connection
im up to the "testing the connection" step,
the apm doesnt seem to respond to anything i type
this is what i get in terminal (ssh to the pi from mac)
pi@raspberrypi ~ $ mavproxy.py --master=/dev/ttyAMA0 --baudrate 57600 --aircraft MyCopter
Connect /dev/ttyAMA0 source_system=255
no script MyCopter/mavinit.scr
Log Directory: MyCopter/logs/2015-09-09/flight5
Telemetry log: MyCopter/logs/2015-09-09/flight5/flight.tlog
MAV> Waiting for heartbeat from /dev/ttyAMA0
none of the commands suggested on the above url have any response, idk whats wrong,
can someone please tell me what is happening?
  • Thanks for your reply Rob.. I even face some problem in starting the isc-dschp server.. stating the error failed, more over i found that etc/inittab configuration file seems to be empty without any script. If possible pls help me with this issues too..
    Regards
    Nijandan.
  • Hi Rob
    Did you got the solution for this prob?
    Coz me too facing the same problem .
    • yes i did find a solution,
      i havent done anything with it in the last month, will need to get my pi back on my network so i can ssh it,
      then i will post the solution here.
      it will be in about 24 hours from now
      • 13 days later...
        I'm having the same issue. Would you post your solution? Thanks!!
        • Hi Guys,
          I am trying to set up mavproxy with a raspberry pi 2+ pixhawk using the instructions here:
          http://dev.ardupilot.com/wiki/raspberry-pi-via-mavlink/#Testing_the...
          I'm up to the "testing the connection" step,
          the pixhawk does not seem to respond to anything I type
          this is what I get in terminal (ssh to the pi)
          Any solution is appreciated!
          Thanks.
          • Problem still continue...
            Any suggestion on this issue?
            Thanks in advance.
